Roof Light Bar and light suggestions?
Hello all.
Looking for suggestions for a roof top light bar and lights that others are using. I do a lot of camping in remote areas, so having better lighting would be great on my 2000 Disco 2.
Also looking for any individual light rain gutter brackets that would work for lights. I have a camping trailer and it would be great to have work lights mounted high on the back for setting up camp after dark, which occurs a lot of the time with my schedule. I work a lot with Scouts and have to sometimes be the first one in a camp area.
Pictures of your set up would be great, as well as vendor sources.
Thanks!!
Thanks!!
I run flood lights from baja designs on the sides of my roof rack, a BD Squadron sport combo pattern facing the rear on the roof rack as a work/dust light. I have hella valuefit on the front of my roof rack as they look the part and didn't break the bank. Forwardfacing roof lights aren't as useful as people want you to think due to glare, I much prefer bumper mounted lights and in that case I've gone through cheap lights and don't recommend them. Diode dynamics makes the SAE legal fog lights of my preference, in a 3" pod or a 6" bar. For better light output you can do facelift headlights and retrofit HID projectors into them, this leaves the stock highbeam location available to add a lighting option in the housing, not cheap but cheaper than 2 LP6 baja designs lol
Definitely interested in this too! I want to mount more lights... totally not for the looks... But being known for arriving to camp late its nice to have the extra lights. I've already started on lights underneath the rear bumper. That way when I drop something I can easily see it. Its also convenient to see the ground without a headlamp or flashlight.
I made a simple small "front" roof rack out of some extruded aluminum to which I have some "amazon special" round LED lights mounted. I went this route for a few reasons:
1) Extruded aluminum is ideal for small custom frames if you don't have any experience with tube bending or welding (both of which I'm bad at) you can pick some up on which allows you to make your own custom size. You can also bolt your lights directly to the channel.
2) LED lights don't draw a lot of amps so I was able to use smaller gauge wire which fit easily under the exterior A-pillar trim
3) Cheap-o lights because I don't use them that often- but they light up more then enough when I need them! I like the classic round style myself.
I do want some "rock lights" for camp setup- the problem with the roof lights is that because I have the roof top tent that determines where the vehicle is oriented and big lights on top are often not pointed in the right direction for setup- but some underframe rock lights...that might do the trick!
Roont (04-20-2024)
1) Extruded aluminum is ideal for small custom frames if you don't have any experience with tube bending or welding (both of which I'm bad at) you can pick some up on amazon which allows you to make your own custom size. You can also bolt your lights directly to the channel.
