-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Rough Runnig / Check engine light (https://landroverforums.com/forum/discovery-ii-18/rough-runnig-check-engine-light-60125/)
gretaweaver Jun 28, 2013 04:12 PM
I have a 2000 LR Discovery 2 with ~140,000 miles (my first :) - I have had since Sept and I LOVE it!!). The check enging light would come on, she would run alittle rough then it would go off. The light is now on all the time, run fine until the light blinks - then runs rough, slow accelleration - then stops blinking and runs fine
We have changed the plugs, run seafoam - we have new wires, but we cannot get to the back to change them. We are thinking O2 sensor or catalytic converter - any thoughts??
ralphobell Jun 28, 2013 04:14 PM
Take it to Autozone and have the codes read, then we can help.
bballjames Jun 28, 2013 04:22 PM
As Ralph mentioned, get the codes read. Also, are the wires original?
Disco Mike Jun 28, 2013 05:33 PM
I hate to repeat what has already been mentioned twice.
Get the fault code numbers before you do any repairs or you are just guessing and that is not something you want to do with a Rover.
jfall Jun 28, 2013 05:57 PM
Stop driving it now.
The check engine light flashing means that
the catalytic convertors are being destroyed by unburned gasoline.
The check engine light flashing is saying "Emissions systems damage taking place"
You keep driving it like that -
the catalytic convertors will super heat maybe and melt all things around them.
You will ruin the catalytic converters.
Stop driving it.
It was sold - for a reason.:eek:
Now you know the reason.
gretaweaver Jul 3, 2013 12:08 PM
I got the codes checked..it state multi-misfire 13457
P1300, PO3008 or B, PO301B, PO303, PO304B, PO305B, PO307
jafir Jul 3, 2013 12:57 PM
Codes are P=power train. The rest are numbers.
0=industry standard
1=manufacturer specific
You shouldn't have p03008, that's too many digits. I'm guessing its p0308, misfire on cylinder 8.
gretaweaver Jul 3, 2013 02:13 PM
I am not sure if they are the original wires or not. We do have a set of wires ready to go on - we just couldn't reach the back of the engine..are there any tricks??
I really appreciate all of everyone's input!! I have always wanted a Rover and I finally have one and I love it and I want it to last forever :)
bballjames Jul 3, 2013 02:52 PM
It is tricky.
Read this: https://landroverforums.com/forum/di...oving-im-9657/
bballjames Jul 3, 2013 02:54 PM
Also be sure to replace plugs at the same time.
