Runs a little rough
Runs a little rough
Just resurected the Disco, and runs a little rough thru 2300-2800 RPM most noticable under acceleration and higher gears.
Had all the plugs and wires out when dealing with the oil prime issue. Used marvel in the cylinders while dry cranking (fuel pump relay pulled and coil pack unplugged). Smoked like heck on initial start. Think I might have fouled a plug or damaged a plug wire (about 20k on them).
No lights on, and smooth idle @7-800RPM.
About 1/4 tank of the gas sat for about 6mos. Treated with seafoam and premium.
Start at the plugs?
When I replaced the wires I got them from dealer (not too bad). AutoBlone...Zone has a set of Durilast and Bosh. Should I wait? 122K on 96 DI.
Start at the plugs?
RE: Runs a little rough
I had very similar symptoms, I just bought a set of wires through the LRR store, they arrived in 3 days, and I finished the job this afternoon. I opted not to remove the plenum, and do it over the back of the engine instead. I'm glad I did, it went pretty well. Running great now! Don't bother with cheap ones, you don't want to do the job twice.
Several people have told me to stay away from NGK's on a Rover engine. I've not tried them on mine yet for that reason. I swear by them on Japanese cars though. When I used to have Japanese m/cycles I had Champion spark plugs failing all the time. The NGK's never failed. I think bosch +4's are the plug of choice on this forum? I'll be trying the Bocsh's on my next plug & wire change/upgrade.
