Safety Device Safari Roof Rack
Hi, I searched the forums and also Google but I cannot find the answer. Does anyone know if a Safety Device Safari roof rack built for a Discovery 1 fit a Discovery 2? I know that the Series 1 is a bit shorter that a Series 2 and I was wondering if I purchased a Safety Device Safari roof rack made for a Series 1 what kind of problems I can or will encounter if I installed it into a Series 2. Thanks.
Yes, it will. It will just be short at the rear.
Thanks, would you know how short?
Quote:
you have to be logged in to the LRRforums to see that link...
Just an FYI, Safety Devices has been talking about doing another run of D1+D2 racks with enough demand...
rack
I use a DII rack on my D1, and as the DII is longer by 4/6 inches at rear. The rack for a D1 will be that much shorter.
Both ways they look ok |
Quote:
The roof rack for the Discovery 1 (RRL104 0RRA) would be the same width as the Discovery 2 but it is shorter length than the Discovery 2 so there would be a 15-20 cm gap between the end of the roof rack and the end of the car. So 15-20cm is around 6 - 7 1/2 inches... |
| All times are GMT -5. The time now is 06:22 AM. |
