saggy front springs
yeah it just seems like the front of my rover sits a little lower than some of the other discos i see in town.does any one know the proper measurement from the center of the wheel hub to the bottom of the fender arch?
and if it is sagging just getting new springs will fix that problem right? thanks much |
Your whole truck is probably sitting lower then a lifted Disco, with the miles you have.
Rovers springs settle and usually at 50,000 mile plus you will drop about 1.5"s and you will have lost most of your ride quality. Time to do a small lift and get it back up. Do you have SLS, if so, that is why the rear isn't dropping. |
