-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   scan tool and code reader (Atlantic British) question (https://landroverforums.com/forum/discovery-ii-18/scan-tool-code-reader-atlantic-british-question-47219/)
kpl1228 Feb 4, 2012 09:14 PM
Any of you guys got one of these? What will it do and what won't it do (I need something to clear service engine codes and 3 Amigos). click link below
Scan Tool & Code Reader - Basic Plus - OBD2 Diagnostic Tool By Innova With Live Data & On-Screen Code Definition (D3040 Same Fit As Genuine Part # 3040) - Land Rover diagnostics from Atlantic British
Savannah Buzz Feb 4, 2012 09:23 PM
Justa a code scanner. Won't do the Amigos. See http://rswsolutions.com/index.php?op...d=56&Itemid=55 for one device.
Also consider the Ultra Gauge as a code reader scanner (also won't do Amigos, but makes a great dash gauge for most everything else). UltraGauge Automotive Information Center and OBDII Scan Tool
kpl1228 Feb 4, 2012 09:59 PM
the rswsolutions unit won't reset service engine light though?
Savannah Buzz Feb 4, 2012 10:02 PM
I don't have a D2, so have not had that demon. May have to use a regular reader for that, but you should be able to do a search on here for that Amigo device. Moving up the hill is the Hawkeye, which does both and more, in the $500 - $600 range. See Hawkeye Diagnostic Tool for Land Rovers - D.A.P.
Spike555 Feb 4, 2012 10:11 PM
You are in a ton of luck because you own a DII, you my lucky friend need two, thats right, count them, TWO scanners, one for the engine codes and yet another for the ABS codes.
So you can spend the $85 plus shipping on the one that AB sells and then another $200 on the ABS Amigo.
Or you can spend $80 delivered for the Ultra-Gauge and another $200 on the ABS Amigo.
I have the Ultra-Gauge and I LOVE IT!!
Or you can go all out and buy the Hawkeye which will do everything.
kpl1228 Feb 5, 2012 06:51 AM
good enough for me----ultra gauge sounds terrific. Thanks all
Charlie_V Dec 26, 2016 11:55 AM
I have the iCarsoft i930 (about 100 dollars) which is a full scanner and resets all systems (even srs and abs) and is land rover specific. But I found a newer one that looks even better... "iCarsoft LR II for LandRover" on Amazon. $165.
MetalMarine Dec 26, 2016 12:46 PM
i also use the iCarsoft i930.
Does the iCarsoft LR II turn off the sls or still need a hawkeye for that?
the iCarsoft LR II looks pretty nice though.
ArmyRover Dec 26, 2016 01:04 PM
Damn Charlie a 4 year old Zombie thread :)
Charlie_V Dec 26, 2016 02:07 PM
Oh shoot. My bad!
