Sea Foam
I'm considering doing the SeaFoam induction cleaning on my 2003 Disco.
I found this detailed information on using Seafoam and hope to get some input on the accuracy andapplicability to the Disco. http://www.ls1tech.com/forums/showth...hlight=seafoam MWmG |
RE: Sea Foam
I wouldn't put it in the crankcase. Do an ATF flush. I have used 2/3rds of a can on the induction cleaning, just as described. I haven't used the deep creep on the T-body. I actually use THrottle body cleaner to get that one. Use the seafoam, clean the T-body and then do a flush with ATF.(drain oil, fill with ATF DO NOT DRIVE!! Idle for 20 min, drain and fill with your favorite oil. I would change the oil at 1K after that just to get out any ATF that may have stayed..
Viola! New Disco |
RE: Sea Foam
Thanks,
I did the ATF flush last week per your advise. Worked well.Working on the 1000 miles to change the oil again. MWmG |
RE: Sea Foam
Do the induaction cleaning before you change your oil. Seafoam might creep past your rings and blow out the carbon built up.
RE: Sea Foam
Why flush with ATF vs just another cheaper mineral oil?
RE: Sea Foam
ORIGINAL: ajh Why flush with ATF vs just another cheaper mineral oil? |
