Seat control panel removal
Searched for the answer but no go. I have a right seat control panel that the switch has broken away from th inside of the panel. Button fell off. I think I need to remove the panel and re attach the switches to it, so the buttons can be re pressed on.
How do you remove the panel. feels like tabs on the bottom to push up and release, but don't want to crack it. Also, do the control button just press back on? Thanks |
I seem to remember that they slide. Look at the video for installing a 2004 CDL linkage. It shows you how to remove them in the video.
installing a CDL in land rover - Bing Videos |
Dead link (I think). Anyone know if it exists elsewhere?
Originally Posted by Fallstaff
(Post 698465)
the seat switch control panel should just pull out. i believe that the knobs press on. the back half of the switch attaches using a weird sliding clasp mechanism.
The top tabs are flexible, the bottom tabs aren't. Push down the top tabs and lever it out, than lift upwards.
| All times are GMT -5. The time now is 02:52 AM. |
