Seat wont move .. need help
i went to move my seat and would not move. i switched the switch to the passenger side and the switch worked fine. any idea in what might work would be great.
Did all the function of the drivers seat fail?
Have you checked your fuses? |
i pluged the switch into the passenger side and the switch worked... The heated seat also works on the driver side.. the fuses are all good not to sure about the relays.. im running out of ideas on what to do
its fixed now... it was the relay im glad thats all it was
| All times are GMT -5. The time now is 01:33 AM. |
