Selling 2003 Landrover Discovery....
  #41
Old 01-14-2019, 05:26 PM
disco2003NYC's Avatar
This doesn't look corroded?
  #42
Old 01-14-2019, 05:48 PM
Saturnine's Avatar
i mean, i personally would say that looks corroded
  #43
Old 01-14-2019, 07:01 PM
mln01's Avatar
Originally Posted by Sixpack577
The booster on my 04 was almost eaten through with rust.
The MC(which the po had replaced), was leaking and brake fluid ate the paint.
With the leak fixed the bottom and front of the booster were badly rusted.
I got a new booster, and replaced it.
The old one wouldn't have taken much effort to push a hole through, and another winter would have done it in.
As metal was eaten away.
There's a big difference between surface rust and corrosion that could cause the brake servo or any other part to fail. Sixpack577 says the brake servo on his truck was almost eaten through. I'm not going to argue with what he reports - he was there and I was not - but it seems his experience is an outlier. Regardless of that, it's true that replacing the brake servo is not difficult. Brake boosters rarely fail so they are inexpensive used.
  #44
Old 01-14-2019, 07:20 PM
Blanco.se7's Avatar
I am up for the challenge. Forgetting how bad the leak. When I get into the car after a couple day not driving (and its really cold outside) the steering wheel feels completely locked. It take 5/10mins for it to loosen up once I fill it with fluid. Is this what it is? Can you tell me what I need and how to do it? I also think I should get a underwash, when the shop had it up doing and oil change the bottom was soaked leaking all over!
get the wash, full it with power steering fluid and check where it leaks from, could be a hose ($25 fix) or a actual pump ($90 fix) or could even be a loose connection, first step is probability a nice wash and a bunch of engine degreaser
  #45
Old 01-14-2019, 08:27 PM
Sixpack577's Avatar
I would take a picture of the old booster, but it went in a friend's scrap pile last year.
The paint on the bottom center of the hole behind the MC, and at the bottom of the booster had bubbled, and was full of rust underneath.
The metal was rotted thin, and springy and crunchy if you pressed your finger on it.
Enough to the point that bumps and vibration would've eventually caused a hairline crack or pin hole, and likely in the near future, it didn't look like it had another winter left in it.
Not a gaping hole either, but just enough to cause a vacuum leak.
I changed it for piece of mind.
I'm not saying it's common, but it happens.
According to CarFax, my D2 spent 4 winters in the north east, so that along with a leaking MC to eat the paint off first.
  #46
Old 01-15-2019, 07:33 AM
Extinct's Avatar
Received 1,400 Likes on 1,000 Posts
The rust on the master cylinder is just surface rust, far from being significant at this point. If the mastercylinder was going to be rebuilt instead of replaced it could easily be addressed with a little sandpaper or rust remover and paint.
As to the leak, power steering fluid has a fairly high detergent content, it might have done a reasonably good job at that leak rate of essentially washing the area off. I would suggest starting sticking your phone down in the leak area and taking some flash photos so we can see how serious a degreasing it needs. Then it will likely be easiest to start with aerosol brake cleaner to spray off the affected components so we can see the leak source.
Good luck.
  #47
Old 01-26-2019, 11:00 AM
Hi sorry for the lack of response. Been filling the power steering fluid up and moving the car from alternate side of the street parking now for 2-weeks. Need to make a decision on what to do. Any NYers, Long Island or NJ forum members here who can recommend an inexpensive shop to figure out how bad the leak is and if it's worth fixing? I need to make a decision whether to donate the car, sell or fix it.
Thanks in advance!
  #48
Old 01-26-2019, 11:11 AM
mollusc's Avatar
if the weather warms up enough to be able to work on it outside, i could meet you somewhere and take care of replacing the booster and/or master cylinder with spares from my parts truck. i have a brake bleeder system that i will be testing on my own truck within the next few days tat should complete the whole repair.
i'd be able to take a look at the power steering leak at the same time to see if i can work out where the problem lies. after identifying that, the course of action might be clearer.
  #49
Old 01-26-2019, 11:27 AM
I am happy to drive to Staten Island. Let me know. I can come next week. That would be amazing!!!!
  #50
Old 01-26-2019, 06:03 PM
Extinct's Avatar
That is a very generous offer! Good people in here
Quick Reply: Selling 2003 Landrover Discovery....
