Service Engine Soon Light flashed Me...
yesterday i was on my way to go get a pressure test as i am still losing coolant... called the shop where i was to get the pressure test and asked them "do i need to be topped off so you can do the test" and they said "yeah if you got a leak, you dont want to run it dry, so just put water in it and come on over". i really didnt want to put straight water in the cooling system, but it needed something in there, the level was only a couple inches from the bottom of the tank. drove over to have the pressure test and it read good, holding pressure nicely...
well as i was driving over to the shop the SES light started flashing at me... i have a scanner, i will post what the codes are...
0305 - cylinder 5 misfire
0300 - multiple misfire
1170 - Downstream fuel trim malfunction (bank 1) Front sensor aged - rear HO2S adaption too lean/too rich LH bank (NAS and EU-3 only)
1390 - Misfire detected at low fuel level Misfire detected with low fuel level
0307 - Cylinder 7 misfire detected
1300 - Misfire detected sufficient to cause catalyst damage
0301 - Cylinder 1 misfire detected
0133 - O2 sensor circuit slow response (bank 1, sensor 1)Front sensor aged - period time too long/too short LH
0137 - O2 sensor circuit low voltage (bank 1, sensor 2)
0134 - O2 sensor circuit no activity detected (bank 1, sensor 1) Front sensor LH bank open circuit
OK all those misfires and O2 codes are on your drivers side so maybe your coil pack is bad on that side.
