-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   SES light - Code P1416 (https://landroverforums.com/forum/discovery-ii-18/ses-light-code-p1416-13299/)
KeizerRover Apr 14, 2008 08:13 PM
The SES light came on today and my code reader said it is a P1416 which seems to indicate something with the Secondary Air Injector system. I cleared the code and the light went off. What should I watch for now or be concerned with?
Thanks.
Spike555 Apr 14, 2008 08:52 PM
RE: SES light - Code P1416
Emissions service is due.
KeizerRover Apr 14, 2008 09:07 PM
Okay, what all does that entail?
Disco Mike Apr 14, 2008 09:09 PM
I can't find the 1416 code, but I don't believe it is a service light for the secondary air, believe it is more of a failure issue.
wooz797 Apr 14, 2008 09:56 PM
port air circuit
manufacturer specific- dont guess that helps
KeizerRover Apr 15, 2008 12:45 AM
P1416 SAI system fault (RH side) - air delivery not reaching catalysts
Suggestions???
WolfPack Apr 15, 2008 07:15 AM
I've heard of the SAI pump/valve actually getting clogged up, and all it needs is a good cleaning. Once that valve grinds to a halt, it'll trip a SAI failure code. You might want to try cleaning (I think a shot of carb cleaner up in the valve will work...cleaner, soak, compressed air, repeat.
If carb cleaner is not SAI valve safe, please correct me!
jdelp Apr 15, 2008 07:35 AM
Carb cleaner, WD40 or any lubricant/solvent is good. I clean my system about once a year, just remove all the hoses and you'll see the old oil and residue clogging the hoses. Your problem could easily be due to a loose hose, I've now had to zip tie a few on the vacuum pump for the SAI because they begin to slip off. I don't doubt that you could have a bad valve or pump, but try cleaning it and see if it helps.
