Short in dash when using blinker?
Never heard of this before: When I use my turn signals, the little light in the dach that shows a trailer flashes with the blinker... There is a split second of a delay between the moment the blinker light goes on and the trailer light goes on. Any ideas what that could be? This is on the 2001. Since I don't have that happening on the 2000, I figure it is something odd going on...
Cheers!
Cheers!
The trailer indicator is supposed to flash once if the trailer circuit is fine. If it continues to flash as long as your turn signal is on it indicates a problem in the trailer wiring. Don't not worry about it has been suggested. There is a problem that could lead to other problems if not dealt with.
It is like a turn signal indicator for your trailer, it "self tests" everytime you use your turn signals when no trailer is hooked up.
