Shuttle valve replacement
Hi as Ive posted before I have the 3 Amigos plus the break light on. Ive been reading that I should replace the shuttle valve seals. Would it not be better to just replace the valves as well as the seals at the same time. My 03 Disco has 97k on it.
Thanks Aaron |
i don't have an answer for your question really. but i'd be in the mindset to not necessarily replace what doesn't need it. upon inspection if it looked bad, then i'd do it, otherwise just the seals most likely.
also, have you seen this? ABS Mod - LAND ROVER CLUB V.I. |
Read the sticky at the top of this section before you do anything, Then get the codes read. If the module is showing a fault, you do the valves, seals and new ground wire along with whatever faults are found, when done, do a full 2 quart DOT 4 brake flush.
X2 on what Mike said: Read the Sticky. All of it.
I just re read the sticky and that makes perfect sense, I bled mine at the bleeders when I flushed the system. When I replace the seals I will bleed at the Mod...Thanks guys so much. I also have a post about the brake dash light being on even after flushing and changing pads and rotors.
No, when you are done rebuilding the module, rebleed at the wheels till you get clear fluid which normally will take about 2 quarts of DOT 4.
Okay Mike will do, I just did the brake fluid so It should not take much when I do the module. Thanks again.
I can buy the Wabco shuttle valves for $80.00 shipped but no seals included just the bolts. I think the falcon kit is a little expensive and its not even the brand name. For valves and seals on Falcon its $140.00 shipped. Like I said I am going to buy a Wabco replacement on the valves for $80.00 shipped and if forced to buy the seals from falcon for $49.00 shipped. Anyone know of another place I can get the seals at? I think that $39.00 plus $10.00 for shipping is a rip off for 2 pieces of rubber.
Originally Posted by aarongregor
(Post 280175)
Yes, the price is crazy, but replace the seals when you do the shuttle valves or they will just fail again.
| All times are GMT -5. The time now is 09:40 AM. |
