| grandkodiak |
May 8, 2011 07:17 PM |
shuttle valve replacement double check, bleed after?
Going to attempt to replace the shuttle valve in the next day or so... if it works maybe ill try the rewire kit on the old one and leave it as a spare haha.
anywho, just double checking... removing the 2 mounts and wedging it up high enough to remove the 3 bolts and single harness to drop the thing down, there wont be any fluid leak will there, i.e. require a bleed after? if so ill have to wait until the weekend to tackle it.
