Slightly comical problem with left blinker
Hey guys I have a strange issue with my left blinker. When I hit the switch to turn on my left blinker, my radio, clock, and odomoter all blink in unison with the turn signal. They blink as if I was turning my lights on and off. It doesn't do it when I activate the right turn signal, only the left one. I did some searching in the RAVE but couldn't locate anything that I thought would be the culprit. Any ideas?
Thanks
Thanks
Without looking at ground/earth distribution in the manual I cannot be certain, but yeah if the share a common ground somewhere close it just might. Or if it's shorting out sending power up the path that feeds the running light filament in the bulb.
So I am thinking there must be short somewhere. One weird thing though, when I unplug all the switches on the cluster with the gas tank release, hazards, SLS, etc. the blinker works fine. (I had them unplugged yesterday and noticed it didn't do it).
So today, I plug everything back in, and it is doing it again. And if I turn on the hazards, they blink really fast. And also, when I use the left blinker or the hazards, the trailer light on the dash lights up and flashes as well. Is this the weirdest?
So I checked all my grounds and fuses and relays. Everything checks out. The problem has escalated though. Now my radio, climate control, clock, cluster, and all lit buttons blink. It's like I'm turning my lights on and off in unison with the blinker. Because of this I am starting to think it may be my blinker stock/switch. Could this be the culprit?
Forgot to mention. All bulbs check out just fine. The blinker works normal when my lights are on. Everything only blinks if the lights are off and the left blinker is activated. Right blinker is normal. Hazards however do the same as the left blinker. Everything blinks. And quickly. Not the normal speed. The hazards act that way no matter if the lights are on or off. Any thoughts?
