-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   SLS to Coil Conversion (https://landroverforums.com/forum/discovery-ii-18/sls-coil-conversion-24774/)
AK Rover Sep 4, 2009 04:19 AM
3 Attachment(s)
Here are some before and after pictures of a D2 that I helped convert from airbags to coils. The owner of this particular D2 will remain nameless. The physical conversion is a lot easier than I expected. I was shocked to find out how little actually held the airbags in place. The coils we installed are OME 762s to go with the 751 front coils.
Attachment 48113
Attachment 48114
Me under the truck having a good laugh about converting it to coils.
Attachment 48115
Urban Panzer Sep 4, 2009 08:10 AM
Looks like Disco Mike's truck to me.......https://landroverforums.com/forum/im...ons/icon12.gif
Disco Mike Sep 4, 2009 08:17 AM
Disco "WHO"?
Tom just couldn't wait to let you guys know that the supporter of SLS has given up.
To be honest, we guessed it right, only about 1/4" lower in the rear know and it seems to ride pretty well.
I am no longer able to do my own work and Tom and a friend offered to help out, which was greatly appreciated.
jycsalas Sep 4, 2009 08:51 AM
Glad it all worked out!
NiteTrain Sep 4, 2009 12:58 PM
whats up with all the surface rust on the rotor? mike, get that rover out on the road/trail and drive it. ;)
lipadj46 Sep 4, 2009 01:01 PM
How are you going to reprogram your slabs unit? Dealer, hawkeye or other?
malmberg Sep 4, 2009 02:12 PM
Did you use the spring perch from a D1? Because I have that exact same setup and my back end is about 1 1/2" off. I have heard the d1 perch will net an extra 3/4". I would like to see some pictures of how it is sitting now. Also how many isolators were used?
Disco Mike Sep 4, 2009 07:33 PM
Nearly 3 weeks of sitting will sure let the rotors rust, but, it is gone now after a drive into the mountains.
Yes, I used a coil can from a D1, my mechanic told me it would give me more lift the the D2 coil can.
AK Rover Sep 5, 2009 02:39 AM
We didn't use any isolators on the coils.
Disco Mike Sep 6, 2009 09:03 AM
As a quick update, especially for any of you that are considering doing a coil conversion, think twice about it. I had a chance to go hit a couple rough roads over the last 2 days and I hate the ride, it is much harsher then when running my 3" SLS set up.
In my case, id made this change because it was cheaper, but beware, you do get what you pay for, fix your SLS, don't dump it.
