SLS Problem
SLS Problem
I get home and my rear right height is way up. I hit the sls button and there was a quick release of air and the whole back sat down like a low rider. I'm guessing the bag broke. My question is, if the height sensor fails, does it continue to fill the bag until it pops? Is this what happened?
on
First, that dash switch is for off road raising of the suspension and is not intended to be used for anything else without throwing a code.
What happens if you close all the doors and hood, start the engine and crawl under neith, do you hear the pump, is there air leaking, go check cause we can't.
The bag seems ok. If I cover the hole, it will not deflate.
but the bag is not bolted on. The drivers side has clips holding it and passenger side is missing them. The previous owner loved to leave parts out. I took a clip from the other side out to see if the autozone has it. As for the pneumatic tube, does it slip back in? I could not find much on this in the rave.
