SLS Problem
I get home and my rear right height is way up. I hit the sls button and there was a quick release of air and the whole back sat down like a low rider. I'm guessing the bag broke. My question is, if the height sensor fails, does it continue to fill the bag until it pops? Is this what happened?
First, that dash switch is for off road raising of the suspension and is not intended to be used for anything else without throwing a code.
What happens if you close all the doors and hood, start the engine and crawl under neith, do you hear the pump, is there air leaking, go check cause we can't. |
The pump is not coming on. I dont hear it and if I put my hand on it, its not vibrating.
I have the sls trouble light and on the top right its flashing the sls logo
You got yourself a code by using the dash switch.
Send me your number and I'll try and walk you thru this. |
I sent you my number. One of the pneumatic tubes on the right side is disconnected. Going to have to take off the tire and put that back.
The bag seems ok. If I cover the hole, it will not deflate.
but the bag is not bolted on. The drivers side has clips holding it and passenger side is missing them. The previous owner loved to leave parts out. I took a clip from the other side out to see if the autozone has it. As for the pneumatic tube, does it slip back in? I could not find much on this in the rave. |
pneumatic tube should thread onto the top of the bag, if I remember correctly
If that is so, then the fitting broke off the tube.
you should be able to buy a airline hose kit or repair kit from any good autoparts supplier. Look at the other side and see if it has a nut on the line.
