So all these codes at once, all of a sudden?
I realize they are 02 sensor related codes, but they've popped up all at the same exact time and for seemingly no reason, as the Disco hasn't been driven in a good month or so until today. What gives? Where should I start looking first?
P0134 P0135 P0155 P0161 P0414 P0000 |
Originally Posted by Street Wolf
(Post 603457)
Originally Posted by LR03NJ
(Post 603508)
check your SAI first if you are having some leak that triggers the O2 sensor fault.
Weird! The P0414 code is a SAI code.
Two of the other codes are are for o2 heater circuits. If the heaters aren't working, they will often give low or no activity codes. Try checking the fuse for the o2 heater circuit. If the fuse is good, check for power at the o2 sensor connectors. |
