so many questions, so little space
RE: so many questions, so little space
I have a 69 Nissan Patrol. There isn't much to them. It has a 4.0 inline sixwith 145hp at 3800rpms235 ft.lb. torque at 2000rpms, 3sp. stick, twin stick transfer, 4:10 gears. It's definitly not fast on the road, but has a great offroading engine. The engine was also used in a big forklift.
Willie
Willie
Here is something that has not been mentioned yet...if you use a Dodge t-case you will need new axles, the propeller shafts will not line up.
LR puts their diffs in line with one another not off set like domestics.
Both diffs are on the passenger side while on domestics the rear is in the center of the axle and the front is on the drivers side.
SO a t-case other than a LR one will NOT work without new axles.
i think it would be easyer and less time to import a TDI from the uk. sure it might cost more then DIY, but it will be done right, and you wont have to spend all that time.
and, everything mechanical on disco's is preatty much set to euro standards. (right hand drive). this causes alot of problems with the axels and transfer case trying to do a conversion.
jasoncrew03
11-15-2010 09:48 PM
cgpilot1id
05-10-2009 09:58 PM
phia@binoco.com
12-10-2006 11:23 PM
