Some kind of cover fell off my td5
Hi all,
Made a turn up hill (on road) and something under the car went clatter and i noticed a plastic cover in the middle of the road behind me.
Managed to stop the car and reverse before it got run over.
It's mine, its got Land Rover written all over it.
Can you tell me where about it came from, so i don't have to get under the car too much on this sodden ground.
Cheers
Stuart
Cheers
Stuart
Isn't that the cover for the air pump suspension??
Covers this:
https://www.ebay.com/itm/USED-OEM-WA...NZ35tD&vxp=mtr
Covers this:
Give that man a prize, you are correct sir!
Just the cover is part #: 8510132 > 8510132 | BOX - AIR SUSP COMPRESSOR DISCO11 | Land Rover | Discovery 2 - 1999 to 2004 | Britcar (UK) Ltd
BUT most likely you will only need 2 new fasteners (ANR6461)to keep it in place > https://rimmerbros.com/Item--i-ANR6461
ALSO check the 2 female connectors (EZM00110) #3 in the pic are in place > http://www.brit-car.co.uk/product.ph...yer___rad_cowl
Spot on, you lot are good!!
Got under it this morning and see the compressor in all its glory.
Looks rather clean too so guessing its fairly new.
Anyway, i popped the cover back on, tightened the fasteners up and it feels pretty sturdy now.
Cheers for your help, saved me a lot of rolling around on the floor trying to locate where it came from!
Stu
Stu
