-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Sport/Manual Mode (https://landroverforums.com/forum/discovery-ii-18/sport-manual-mode-5762/)
mowthat Mar 2, 2007 06:18 PM
Sport/Manual Mode
Quick question. When in maunual mode should the green {M} light be illuminated? When is sport mode the {S} lights up every time.. And when I first start the vehicle the {M}and
{S} both light up during the initial check. I am sure it switches between the two modes, just not sure if the {M} should light up.2000 Disco II 87000. Thanks
Jake
Aquaholic Mar 2, 2007 11:02 PM
RE: Sport/Manual Mode
M only works while in low range.
Disco Mike Mar 3, 2007 11:33 AM
As mentioned, if you are in low range, using the M mode allows the tranny to be shifted like a manual tranny. Sport mode is for high range and just changes the shifting points and throttle pressure so the truck is a little more responsive.
Mike
