Squeaky noise when Accelerating
Whenever I'm at a complete stop and start to accelerate i hear a squeaking noise coming from underneath likes somethings dryed out. It never makes the sound when I'm in neutral or park giving it gas only when i accelerate driving there is also a tiny bit of vibration. I thought it might be the brakes so i change them all out also changed the oil and the transmission still doing it. Any Help? |
Here is a short video just the squeaking http://s668.photobucket.com/albums/v...1111111001.flv
Thomas22, I am in South Bend too, have you checked the driveshafts for play or have you ever greased the u-joints that are greasable...?
Yes there is some play in the driveshaft when i twist back and forth and i never had them greased i will do that see if it helps i think it might be bad u joints
re-build/replace your front driveshaft immediately. That is a bad u-joint. if it fails, your front shaft will slap the tranny out of the truck.
