Oh my God, I just looked at the brackets holding the bumper on.
Terrifying |
Can someone please post a picture of the originals (oem) bumpers mounted and the off-road (safary) that LR offered, if it's stronger then all the negative talk will be done if its stringer then you may have a valid poinT. I can't give my opinion on safety, however, I'm a AWS Certified welder and without seeing in person and inspecting it I can't give "my opinion", it does looks good
I don't think people are necessarily questioning the weld strength, but the fact that there's one 4"x4" 1/4" plate of steel holding the bumper to each frame rail.
Weld is not in question
If there is anything that is worth over engineering it's stuff like this Saddle the frame as far back as possible with 1/4" or better. 3 or 4 through bolts per side, to sandwich the frame with your saddle. It took me longer to make my mounting brackets than it did for me to make my bumper. |
Originally Posted by Alex_M
(Post 506213)
So, how thick of a pipe would you have to use to weld up your own tubular bumper? I mean, most of these you see don't look that thick, about the thickness of a high quality steel exhaust pipe. Some cheaper tubular bumpers (even with winch mounts) that I've seen are even more thin than that. Could you weld one up out of a thick high quality exhaust pipe and paint it?
Using that thin tube since it's not really structural will be fine as long as you never hit anything. I would not recommend it however. Remember off road clipping a tree or rock with the corner of the bumper is not that uncommon. Hitting it on the corner if it is thin wall and unsupported will bend that back into the tire/body/whatever causing damage. |
Originally Posted by dusty1
(Post 506220)
Ok so boxing them in it is. That won't be that hard as I have to take them off and have them power coated anyway. There is plenty of room in there to do that.
(Post 506221)
The tube portion isn't the part you need to worry about as much. It's the winch mount and bumper mount that are more critical. Also make sure that any recovery points are tied in where there is strength, like at the winch mount or bumper mount area. Bolt in is fine with the proper backing plate etc for the recovery points.
Originally Posted by all4mee
(Post 506232)
Not a bad look, just needs some adjustments. is the winch tray bottom mount only or side mount as well?
