Steering damper won’t fit after alignment
Got an alignment this morning and the tech had to remove my damper because the bracket didn’t line up on the track rod. Wanted to get some opinions first before I get under there and start twisting it... Can’t I literally just turn it a quarter turn so the bracket faces up without messing with the steering wheel getting crooked? https://cimg6.ibsrv.net/gimg/landrov...59ebd3d04.jpeg |
Alignment tech should correct his mistake. He was being lazy and not adjusting it at the tie rod end
Wow!!! Amazing! :D |
Wow seriously an alignment shop left it like that. I just put terrafirm HD 's in and messed up a measurement so my steering wheel was cocked to the right . The alignment shop got the steering wheel square and damper right.
That is just pure lazy |
I know. I’m pissed. Just drove off and saw it lying there on my passenger floor! I’m going back |
If your steering shaft isn't rusted/seized up, then centering the steering wheel is very simple.
There is a groove in the pitman arm that lines up to a threaded hole in the ps box. Thread a bolt in and that locks the steering. The shaft bolt is loosened, and you can slide it out, then pull the u-joint off the splines on the ps box. My steering shaft wouldn't slide, and the front u-joint was bad. I got a reman for $100. Steering is tight, and shaft slides as it should for install/adjustment. Should you replace a steering shaft that won't slide for removal, you either have to unbolt the ps box(4 bolts, frame, driver front fenderwell, simple), or just cut the old steering shaft in half(hacksaw, reciprcating saw, grinder), and pull each end off. The new one will slide and go in without removing anything. |
Originally Posted by Sixpack577
(Post 655108)
Yeah, that's what it looks like he did.
Yep the “easy” way, you paid for an alignment so get it done correctly or find another shop.
Originally Posted by Best4x4
(Post 655119)
