Stranded in the Driveway....HELP
Old 02-15-2014, 02:55 PM
kcdiehl's Avatar
Default Stranded in the Driveway....HELP
Hey guys, went out to start the Blue Monster and nothing.......ugh.
All the dash lights go on but doesn't turn over. It doesn't even click.
Any thoughts?
I checked the starter fuse....
Please Help.
Thanks!!!
Old 02-15-2014, 03:26 PM
04duxlr's Avatar
Check that the shifter is in park, and check the cables to make sure they are right. On my truck, it did the same thing and I crawled under the truck with a hammer and whacked the starter and that got it turning. When they wear out the bushings they can basically short internally and hitting it will allow it to spin.
Old 02-15-2014, 03:55 PM
Disco deuce's Avatar
battery voltage could be to low
Old 02-15-2014, 03:56 PM
kcdiehl's Avatar
I was thinking the starter but it doesn't even click. When my starter went bad on my 03, it at leased made a clicking sound.
Old 02-15-2014, 04:02 PM
Dan7's Avatar
Key fob can imobolize the car. Forget the way to undo it though...should be in the manual.
Old 02-15-2014, 05:18 PM
kcdiehl's Avatar
I have a ultra gauge, I'll check the volt. What should it be around?
Old 02-15-2014, 07:24 PM
kcdiehl's Avatar
I jumped and still no start. Any other suggestions or buy new starter.
Old 02-15-2014, 07:29 PM
kcdiehl's Avatar
Old 02-15-2014, 07:34 PM
well make sure the starter is getting power before you pull it
Old 02-15-2014, 07:40 PM
Jared9220's Avatar
Can you twist your negative battery cable? Try twisting the cables on the battery post to make a good connection and try and start it.
Is the red light on the dash flashing? Try closing all the doors and hood and locking and unlocking the truck at the door twice.
Check the inertia switch under the hood on the passenger side of the firewall. Press the top of it to make sure it hasn't popped up. inertia switch.pdf
Check the ground cable on the alternator bracket.
For your starter. You can try and have someone hold the key forward like they are trying to start the car, and you go underneath and tap the starter with a wrench or something. (don't beat the hell out of it cause you are mad at your disco) Sometimes a bad starter will turn over with a little help.
Quick Reply: Stranded in the Driveway....HELP
