Strange Battery Light Behavior
I've had the battery light on for the last 2 days. I've had no problems cranking or running, but occasionally it's not enough to power the UltraGauge through the ODB port. When the UG and the Battery light have been on together, I've noticed UG Volts were at 11.2-4 and when its the battery light goes away UG Volts is around 13.5. The light isn't flickering and the behavior seems to change with each crank. I drive to the store with the battery light and no UG. When I leave the store its running fine.
Any thoughts? I understand the Battery light will come when alternator volts are less than battery volts, but why would it be changing?
Robert, if you don't have a battery charger that can test the alternator and battery take the truck to any major auto parts chain store. They have diagnostic tools appropriate to your needs that they will use at no cost to you to diagnose your truck's problem.
Just wanted to float an idea out there. Sometimes I go back to look and my problem posts and I see a problem emerge. So I'm starting to develop a theory.
A few months back I was cleaning up after a coolant leak and I noticed the AC compressor bearing blew out a bunch of dust and started squeaking. I've had it on my to do list for a while. Then about a week ago I noticed some slightly warmer temps than normal for no apparent reason. Now my alternator looks to be failing.
Could it be that the AC bearing is causing belt issues which is adding resistance and affecting my water pump/fan and is now slowing down the alternator causing charging problems? It's hard for me to tell just by looking.
robert.juric (03-13-2018)
I took the belth off, the AC pulley spins freely but there is definitely bearing noise. I'm not sure if spinning at speed/heat would more likely induce seizure. Are you saying that even if it seized the belt would slip through and operate as normal? I would think that a slipping belt could have serious problems?
I'm trying to decide if I should replace the AC bearing first and see if that resolves the issue. Or if that would be a non-issue then I would jump straight to the alternator and replace the AC bearing later this month to get ride of the squeaking.
Can't rule out the AC clutch bearing and you really should address it sooner than later. It could be dragging more than you think with the belt and a load on it and you never know when it might seize.
