Subwoofer
I was able to make all the adjustments at my converter and my new amp so I just tapped into the wires that go to the front door speakers (not the tweeters, just the main door speakers). I don't think it matters if you tap into the rear speakers or the front, the main purpose of taping the speaker wires is to create RCA connections.
If you have the Alpine system in your truck, here's a wiring guide:
2002 Land Rover Discovery with Alpine Wiring Information
I would tap into the system at the amp. The trick is going to be dealing with splitting the signals so you send the low frequencies to the subs while sending the highs to the factory amp. The input to the amp is full spectrum, then the amp crosses it over to split the signals. Does the subwoofer you are using have a built in amp or is the amp separate? Many amps can take a line-level input and most sub/amp combos can take a line-level input. Typically, amps have a low-level bypass so you can pass the rest of the signals off to another amp.
the sub I'm using has a built in amp it is a powered sub. i want to just untape the wires in the very back and splice those and re tape them up I'm assuming that will be the easiest way. now if i do it that way which set of wires is it as there are 2 sets in my little area not sure what to call it. if i tap into the amp would i just on the output side of it find the colors that are in that wiring diagram?
P.s how do i know if i have alpine or not
