Suspension and Weather
I've been having a suspension issue in the back of my 00 Disco SII for a long time now. The rear usually stays low, and often the passenger side drops all the way -- the wheel is just short of hitting the well. It will occasionally right itself when the compressor kicks on, but more often than not it stays down. Makes for a bouncy ride!
I've pretty much narrowed it down to a bag leak, sensor malfunction, or a weak compressor. Could be a combination. SLS sometimes fixes the problem, but only if the compressor decides to kick on. And even then it doesn't stay up for very long.
Here's the kicker; it only drops like this during really cold weather.
Any insight?
Any insight?
Any insight?
Any insight?
Cheers
on
This can be pretty common especially on older bags of 80,000 plus miles.
I have seen only a few instances where a bag might drop when really cold and it was a issue that was easily corrected thru the ECU.
Having bad the same problem, I would suggest new Arnott Industries replacement bags, which are easy to install.
Thanks everyone for the suggestions. As for the conversion, it looks like it would actually be a moderately cheaper alternative. I planned on replacing both rear bags, so doing a kit would save me about $20 upfront and spare me the potential for more leaks, compressor issues, etc, in the long long run. Not sure how much more install time it'll need with a conversion though. I don't have ability to run diagnostics... how would I turn off the SLS after converting to springs?
Appreciate it!
Appreciate it!
cgjungdds
05-03-2008 12:45 PM
