-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Sync the ECU to a new stepper motor? (https://landroverforums.com/forum/discovery-ii-18/sync-ecu-new-stepper-motor-24453/)
alanroberts50 Aug 23, 2009 03:33 PM
Ok so I saw something about synchronizing a new stepper motor to the ECU mentioned in passing in the threads, is this something I should try and if so how do I do it?
I recently replaced my stepper motor and no change to high idle. Have tried every other suggestion regarding vacuum leaks and cleaning the throttle body etc.
Don't tell me, let me guess only the dealer can do it!
Thanks,
Alan
Spike555 Aug 23, 2009 03:49 PM
Thanks,
Alan
Ok, I wont tell you.
You need the proper computer equipment to talk to the ECU, if you dont have it then you cant do it.
alanroberts50 Aug 23, 2009 03:56 PM
Thanks Spike, i kinda thought that would be the case but wondered if might just be a case of unplugging and reconnecting the ECU or something, oh well.
Disco Mike Aug 23, 2009 05:25 PM
This is something that you don't need to do with an IAC.
Suede Aug 23, 2009 05:28 PM
Before going to the dealer, try disconnecting your battery for 20 minutes.
Spike555 Aug 23, 2009 05:45 PM
On a DI, yeah you do.
We have had 6 people replace their IACV on their DI's, 5 had to have the ECU remapped for the new stepper motor.
Disco Mike Aug 23, 2009 07:38 PM
Sounds like I will need to do a little checking tomorrow, get back to you.
aiden Aug 23, 2009 09:16 PM
ya ... i'm kinda in the same boat on this one.
i just had my ecu go out and it's kinda shorted out some how o0?
and i am going tus to get the new one done ... good luck and hope you don't have to go to the dealer
