(Post 282908)
Open your copy of the RAVE, workshop manual, emissions controls. It has an electric pump, some solenoid and vac operated valves, and is a known source of "the tick" (but not the only source). Also, if you have a 97, it is not a D2, so it won't have one and you may not find what you seek in this part of the forum. More likely you have oil pressure / oil pump problem, or flex plate cracked (tranny to flywheel interface).
Funny thing I just went outside sto start it and it was quiet as a mouse |
Originally Posted by Discolife
(Post 282905)
where is the sai system and what does it do?
It is a emissions device that injects fresh air into the raw exhaust of a cold engine to aid in the heating up of the catalytic converters to reduce emissions. Cats only work when hot, the faster they heat up the less pollution. |
...and FTR, I don't have SAI. Ever since last January or so, it has been almost quiet as a mouse, less what I believe to be a small exhaust leak causing a faint tick, which I haven't looked into yet.
| All times are GMT -5. The time now is 04:57 AM. |
