Temperature normal, rises and then falls without overheating
I had coolant problems a few weeks ago with my '00 DiscoII overheating. After the help of this group, I tracked it down to the coolant pump and so that has been fixed.
Now, most of the time it runs nicely at the normal operating temperature (according to the gauge). However, occasionally the temperature rises and then drops without overheating (no red light). This can happen around town as well as after a long hill. When the temperature goes up, I can see the water boiling in the coolant tank and a little steam coming off the tank. I've change the coolant tank cap, so don't think it is that. However, if it was a fault in the coolant tank itself I would expect to see it overheating all the time rather than intermittently.
I used an OEM coolant tank cap, so one idea I had was that perhaps it was not up to specification for the truck. This would cause the cap to 'let off pressure' at too low a rating? What pressure rating are official caps supposed to have?
Snafu / Disco Fries
03-11-2021 06:39 PM
buick56
05-04-2013 10:31 PM
RROJ
08-20-2010 10:07 AM
