Tensioner Pulley
Old Dec 31, 2010 | 10:06 AM
discobob's Avatar
Default Tensioner Pulley
Any write ups out there on replacing the tensioner pulley?
Old Dec 31, 2010 | 10:08 AM
Long Haul's Avatar
Pretty easy fix. Remove belt take bolt out of the center of bearing replace pulley and reinstall in reverse order. Just make sure you get the belt back on properly.
Old Dec 31, 2010 | 10:14 AM
lordmorpheus's Avatar
It's pretty much just put wrench on pulley bolt, pry tensioner up, remove belt from alternator pulley to allow slack in belt, remove tensioner pulley from tensioner, replace pulley, reinstall belt in reverse order.
Why just the pulley, instead of the whole tensioner? At that mileage, I would replace the whole thing (same instructions as above except unbolt tensioner from engine instead of removing pulley from tensioner).
Old Dec 31, 2010 | 04:33 PM
discobob's Avatar
Done. Easy. Thought about replacing the whole tensioner, but it seemed in fine shape, Very tense. Plus, the pulley needed replacing TODAY. Suprised it didn't blow apart already.
HAPPY NEW YEAR ROVER PEOPLE!
Old Jan 1, 2011 | 10:08 AM
Normally if that pulley is failing the other 2 idler pulleys are close behind.
Old Jan 1, 2011 | 12:26 PM
bosshogt's Avatar
Any thoughts on a preferable brand of tensioner pulley and idler pulleys?
I really like Gates, but from their website they only make the Serp belt.
So I guess we are left with factory LR, Dayco, All Makes4X4.
Old Jan 1, 2011 | 02:15 PM
discobob's Avatar
The one I bought is a Gates. About twenty bucks at O'Reilly Auto Parts.
Old Jan 1, 2011 | 10:31 PM
bosshogt's Avatar
Thanks Discobob,
I found the full kit here at Atlanta British.
http://www.roverparts.com/Parts/ERR6439K.cfm
I did also found the pulley at Orielly that you mensioned for $19.99. It only listed 2000-2002. So I dont know about 03/04 years(mine is a 2003). It would'nt be the first time my year was not listed in their database, but the part would fit just fine. I also found out the the two idler pulleys...one is 70mm and one is 80mm. Probably can tell by looking for the 10mm diameter difference.
http://www.oreillyauto.com/site/c/de...d=pulley-idler
Old Jan 4, 2012 | 02:29 PM
fj60disco's Avatar
I think the NAPA brand may be a better pulley....IMO
NAPA AUTO PARTS
Old Jan 4, 2012 | 09:25 PM
kenk's Avatar
When I did mine, I replaced just the bearing in the pully. My '04, if i remember right, was like $45 a pulley. New bearing for $8.
Correction: bearings was for the idler pulleys- tensioner I got complete at autozone.
robbster91
Jan 7, 2010 07:11 PM
jycsalas
Apr 1, 2009 07:43 AM
souljad9
Nov 19, 2008 11:50 AM
andrewmcoffin
Mar 10, 2008 08:52 AM
ajh
Dec 19, 2007 11:30 AM
