-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   THERMOSTAT (https://landroverforums.com/forum/discovery-ii-18/thermostat-9319/)
Spike555 Oct 13, 2007 03:12 PM
THERMOSTAT
Does anyone know where I can get a t-stat gasket without having to pay for shipping?
'97 Disco1 4.0
Autozone says N/A, maybe NAPA? It's late Sat. and NAPA is closed till Mon.
okdiscoguy Oct 13, 2007 04:10 PM
RE: THERMOSTAT
The dealer isn't too high. I got my T-stat and gasket there because the genuine t-stat has a bleed hole in it.
Mark G Oct 13, 2007 05:19 PM
RE: THERMOSTAT
I highly doubt you will find a parts store that will have one on hand. If you have a local L/R dealer, it's possible they might have one,our local dealer didn't.
I changed mine last week. I just cleaned the existing gasket, scrapped off the rubber coating, then applied RTV. No leaks. Otherwise, get some rubberized gasket material in a roll and you can make one really easily. Trace around a cup or glass and cut out.
Mark G
Mark G Oct 13, 2007 06:19 PM
RE: THERMOSTAT
Yeah, I would stick with the dealer stat too. The one I got from Autozone wasn't the same temp range ...and cost about the same. It did have a bleed hole, but it was a hair smaller. But if you need one right away, the autozone unitshould work fine.
RamblingMan Oct 13, 2007 07:36 PM
RE: THERMOSTAT
Hi,
At autozone did you ask for a disco thermostat or some other car that fits. I tried pepboys, carquest, napa, advantage, and autozone: all said they didn't even have it listed in the system.
BTW, I have a 94 disco.
RM
Spike555 Oct 14, 2007 10:36 AM
RE: THERMOSTAT
I used RTV sealant when I replaced the t-stat hoses and coolant 2 months ago but it has now sprung a small leak in the past week.
Have not had to add coolant but there is a quarter sized puddle on top of he engine.
