Right, but the stock system puts no load on the bar, ever, and is thinner?
just face it Zack .... You have an inferior rig :p
I have sway bar disconnects in the front, and no sway bar with a panhard conversion in the rear, I am not worried about ACE's sweet bendy tricks :p
1 Attachment(s)
hehehehe
ha! there's other ones out there that keep me sized correctly.
I bet this one has ACE :) http://static.ibsrv.net/autocomm/Con...Duty%20(2).JPG |
Wait. Are they headlights I see hanging from the sway bar?!
Nioce! And why does this truck need a winch? |
Haha because even though it's 15 feet tall, the axles are still on 16" off the ground.
Originally Posted by ZGPhoto
(Post 428820)
The ACE system does not load the bar when the tires are uneven at low speeds (under 25 mph). The ACE has thicker bars because, when the system is loaded, it sees more torsion than the stock system. |
Originally Posted by acamato
(Post 428874)
The stock system will have no load when the wheels are level (at the same height). When the tires are not level the sway bar is loaded. If the stock system puts no load on the bar, why do you have disconnects?
The ACE system does not load the bar when the tires are uneven at low speeds (under 25 mph). The ACE has thicker bars because, when the system is loaded, it sees more torsion than the stock system. I have disconnects because every sway bar ever limits articulation, even more-so when it can't bend at all. Point being, there's no way an ACE setup could have more articulation unless the ACE system literally forced the sway bar to bend. |
1 Attachment(s)
(Post 428883)
The ACE system has the same force on the bar while articulating,
The two ends of the bar aren't rigidly connected. Without the hydraulics they will move independently. Attachment 18654 |
