Three Amigos and ABS Amigo
I finally purchased the ABS Amigo and am very happy with how easy it is to use. It immediately cleared my three amigos and they have not come back on after 100 miles. The logged faults show: front right sensor bad output and 114: shuttle valve electric failure. Two questions:
(1) If the three amigos are not on, do ABS, TC and HD still work? and (2) What is the best way to follow up on the logged faults to see if I can correct the problem? Thanks! I'm finally getting my LR back to working and really loving it. |
1 yes they are working. when your fault reoccurs, your lights will come back
2 solution for 114 is likely to be option 3 sensor output is likely hub/sensor/connection |
Thanks Dusty! When you say, "Solution for 114 is likely option" what does that mean? Thanks again for your help
He is more than likely talking about the shuttle valve mod, called option b, in these here parts.
Check out the sticky on the home page of discovery 2. |
Yes... Sorry. I think my phone, out thought me. B to the B
| All times are GMT -5. The time now is 08:09 AM. |
