Three Amigos...to TWO Aimgos...
Had the scanner on the ABS module a couple of weeks ago and found that I have an ECU ground issue that is throwing the amigo codes. So I guess I'll be playing with wiring this weekend. The option B fix did not fix my issue, unfortunately. I am more inclined to believe it is a ground wire since it is intermittent and I have found that if it doesn't come on at engine start, a good bump in the road will throw the lights.
