throttle body heater plate questions
https://landroverforums.com/forum/discovery-ii-18/throttle-body-heater-plate-questions-52215/
Gentleman,
I have a 2000 DiscoII, I have replaced water pump, thermal state, radiator, front crank shaft seal, power steering pump and transmission filter, etc.
Just recently engine very hard to start check engine light error code shows engine misfire so I replaced all spark plugs and notice #8 cylinder spark plug contains a lot of oil.
And, coolant level drops, too.
Last night engine overheat light was on, I turn off engine immediately and I found coolant expansion tank was empty, I let it cool down for couple minutes and opened coolant expansion tank cap, coolant returned to the tank to about half tank.
I found coolant leaking out from throttle body heater plate hoses so I removed one of the hose from the throttle body plate and coolant return to the tank again.
Attached please see my pictures, you can see a lot of oil inside throttle especially in the valve cover breather hose.
Can anyone help me?
Thank you so very much!
Sincerely,
Paul
Gentleman,
Can anyone help me?
Sincerely,
Paul
on
Your oil separator may be plugged.
As for being low on coolant, you need to get in the habit of opening the hood a couple times a month and checking fluids, remember it is a rover.
As for right know, chance are you will find yourself with a blown head gasket.
I would have a coolant pressure test performed and if needed, a chemical block test.
Where is oil separator? can you please show me some photos?
Many thanks.
OK I found pictures of oil separator. Valve cover gaskets (both sides) leak out oils, I'll change valve cover gaskets and oil separator and throttle body heater plate at once.
Can I bypass throttle body heater for now? Connect 2 throttle body heater plate coolant hoses together? I need to drive about 15 miles.
Thanks.
I did a pressure test couple weeks ago when I replaced spark plugs, head gasket seems ok.
Many thanks.
Thanks.
Many thanks.
Thanks.
Yes you can by-pass the t-body heater for now.
Buy a can of carb cleaner and clean the t-body.
On the passenger side of the engine is a hose that runs from the valve cover to the intake, remove it from the valve cover.
Inside is a little plastic piece, pull it out, clean it with the carb cleaner, put it back.
Also see the hose in your pic that goes to the t-body? The one that is full of oil?
Remove it, clean it out.
Is your oil milky? Have you seen coolant leaking on the floor? Does the engine overheat when accelerating? Really sounds like you might have a blown head gasket. The throttle body can leak too but I feel you would have noticed it leaking, maybe valley pan as well. Don't ever let the engine overheat into the red light indication, much less overheat at all. Do whatever you can to pull over and shut it off. I've had to shut off on the highway before and coast to a stop because I saw the temp gauge creep up.
Throttle body bypass is pretty simple. In fact mine is still bypassed. I've been meaning to set it up again but it's kind of nice to know that it won't leak.
