Clicking sound...exhaust gasket replace
Old 03-07-2008, 12:11 PM
CL_Reatta's Avatar
Default Clicking sound...exhaust gasket replace
Hi Eveyone, I bought my 1995 Discovery back in July, and over the winter I started to hear a clicking sounds at idle and under load...it gets really bad when accelerating on the freeway. but goes awayif I let go of the gas while driving until it reaches idle speed again.I belive it to be the exhaust gasket but Iam not 100% sure..is there any common problem like this that I should know about, and also does anyone know appoximtly how much a shp would charge to replace the gaskets? Thanks, Brian
Old 03-07-2008, 01:47 PM
Landzu's Avatar
Default RE: Clicking sound...exhaust gasket replace
Yes the bolts on the exhaust manifold do back out, check
to see if they just need to tightened up.
Then shop around to see what it cost where you live.
domyo
09-25-2008 12:19 PM
snorlax
05-08-2008 12:08 PM
snorlax
05-08-2008 12:06 PM
gildedsplinters
02-05-2008 09:55 AM
Northernlight
03-04-2006 04:32 PM
Quick Reply: Clicking sound...exhaust gasket replace
