Tips please
Tips please
alright Im sort of a newbie but I got a lot of info thanks to the forums.
Though I still need a little bit more of info.
Just simple tips. First I have a Land Rover 02 Disco with 90 k.
What are some of the parts that I sould replace?
Im already going to change the Tranny oil at LubNGo. Any advice or things I sould be aware about changing it there?
Next I really not sure whats next. Thats my question now. So I would really appriecate if anyone tells me what to change next.
example. Fuel Pump, Sprark Plug wires, Water Pump, anything ect.
So really I have no idea about the design of the Land Rover or what about it. But what I do know is its an awsome vehicle after 2 years of owning it.
And someone mention to me about the thermostat but I have no idea when that should be changed or what about it.
ThanKS!
Good Day!
ThanKS!
Good Day!
RE: Tips please
Change the u-joints in your front driveshaft (if your joints have grease zerks in them, then it has probably already been done. If so, grease them!)
Do not let anybody do any sort of high pressure flush for the transmission or let them use any sort of solvent cleaners during it. Just do a simplefluid exchange or a drain and refill.
Do a search on this board for "60k mile service" for the big, long list of things you should do. It includes all the fluids and tune-up stuff.
With the radiator you may want to replace your hoses and the thermostat since they are prbably original.I think Atlantic British sells all of the hoses you need as a kit. That seems like maybe a good way to go.
Buy a simple OBD-II reader in case you have some engine codes pop up. It's well worth the $30.
Spend some timedoing different searches and reading this board.
on
1 Post
RE: Tips please
ORIGINAL: savageracer2008
ThanKS!
Good Day!
ThanKS!
Good Day!
Snafu / Disco Fries
12-01-2011 11:54 AM
mr mike
12-15-2006 10:55 PM
alpinab7
11-29-2006 11:27 AM
