tire size
Back to the question at hand...
I've got the 3" terrafirma from lucky 8, and I've got 255/85R16, which are 33". They don't rub on anything, but I've got an aftermarket front bumper. It's possible they might rub if I were to stuff them into the wheel well off road, but they haven't yet. I do plan on getting extended bump stops just in case...
33's and over you will need to re-gear. Our weak axles/joints will not be able to stand up to much abuse w/ tires larger than 33's. As far as whats the largest tire you can stuff under a 3" lift? I'll let the guys w/ the 3" lifts answer this one. I only have a 2"er.
