Tools needed to replace alternator?
I'm in a bit of a jam. My truck left me on the side of the turnpike last night & I'm in need of a new alternator. I don't want to pick up a junk one from AutoZone, so I found a rebuilder to fix up my Bosch one. I need to take a trip down to the towing place and pull it out to take to the alternator guy.
Can someone verify the sockets sizes I'll need for the belt tensioner and to remove the alternator bolts?
I'm at work now, but I'm hoping to scrounge together a few sockets to get the bad alternator pulled out.
Thanks!
Thanks!
You missed the 13. Pretty sure you need a 10 for the ground nut. I think the pos nut is a little bigger (drowssap says 12 which makes sense). Then there are the 2 front bolts which are both either 13 or 15. Pretty much bring 10-16 and you'll be fine.
Oh and a rubber mallet or pry bar because the spacers like to squeeze tight.
remember to disconnect the battery too so the pos wire doesn't ground and arc and explode after you leave.
On a side note. I replaced my alt back in January with factory replacement (not an autozone rebuilt one) that was used because old one was bad. I also replaced the battery with a new one. Now that the weather is in the single digits, when I start the car after sitting all night the battery light is on. All I have to do is blip the throttle and it goes away and doesn't return. I haven't checked anything yet but I figure it might be the used alt already getting weak. Thought??
I helped a neighbor replace his alternator a few weeks ago. The alternator fit very, very tightly in the mounting bracket. Ridiculously and needlessly tight. We used both a rubber mallet and a pry bar to get the replacement alternator in place. Next time I will use a file to shave down the mounting faces on the alternator to provide just a little more clearance before installation. Let the bolts hold the alternator in place.
The tools needed are a 15mm for the tensioner, 10mm for the smaller cable and 13mm for everything else.
lipadj46
11-15-2009 05:59 AM
landRoverNewbie
10-13-2009 11:39 AM
