Towing with my Disco
I've been looking through the manual on my Disco's towing capacity, and I think I've got a pretty good understanding of what it's capable of. I noticed that it has an accessory lighting socket behind the right rear tail light cluster.
Is there a trailer brake set up built in on these guys? If not, is this something I should have installed by a dealer? |
RE: Towing with my Disco
no trailer brake setup, you need a brake control, i would go to rv dealer. cheaper and they do it way more often. I did it myself and it was pretty easy, except i amd pretty good with wiring.
How accurate are the towing capacities listed in the owner'd manual?
I'm moving about 700 miles in a few weeks, and if I can find a trailer to handle it, I'd like to tow my '74 Ford LTD rather than pay for gas in both of these guzzlers. The car weighs in at around 4400 lbs. |
if you have not already found out. Getting to the connector is a pain. I agree with mike on where to get it done. If you have someone else do it for you, ask if they can put a sealed extension for the outside. It will stop future pains when towing. same reasons. hope it help
| All times are GMT -5. The time now is 07:02 AM. |
