Traction Control, ABS and Hill Descent lights on
Old 01-20-2017, 10:26 AM
countryman's Avatar
Default Traction Control, ABS and Hill Descent lights on
Just recently after starting up, the three lights (Traction Control, ABS and Hill Descent Control) remain lit (amber). As far as I remember, there are no associated warning chimes. It seems to happen when I've been parked facing uphill. Restarting on level ground clears the lights.
Any suggestions ?
TIA
Old 01-20-2017, 01:32 PM
hemicharger69's Avatar
Search Three Amigoes in this forum. You will find it is a prevalent problem with known solution
Old 01-20-2017, 03:31 PM
countryman's Avatar
Shuttle valve ? So many threads on this.
Old 01-20-2017, 04:17 PM
Dave03S's Avatar
Get the codes read from the OBDII port and you'll know where to start looking.
Old 01-21-2017, 05:26 AM
countryman's Avatar
You do that only when the lights are on presumably ?
Old 01-21-2017, 06:03 AM
mln01's Avatar
It depends on what fault caused the warning lamps to be illuminated. Some faults get stored for at least several drive cycles even if the fault is no longer present. You will need a code reader that reads ABS codes. Many read engine management codes only. Also, it's odd you get the Three Amigos without the warning chime sounding three times.
Old 01-21-2017, 09:06 AM
countryman's Avatar
Spot on advice, thanks.
"Shuttle valve switch electrical failure"
But then you all knew that
Now off to find out if it's a DIY type job.
Old 01-21-2017, 10:03 AM
Luckyjayb's Avatar
its a diy job. Should take less than 30 minutes
Old 01-21-2017, 10:36 AM
countryman's Avatar
I read the links on the ABS Modulator sticky and I don't work that fast? It would take me that long to bleed the brakes afterwards! Perhaps I'm looking at the wrong place and that there is a faster fix that doesn't need the ABS modulator removing ?
Old 01-21-2017, 10:38 AM
batard's Avatar
No, it's not a 30-minute job. It's DIY-able, but it's going to take significant time and patience if you want to do it right and not just replace the shuttle valve. Do your homework, there are lots of resources.
Quick Reply: Traction Control, ABS and Hill Descent lights on
