Trailer wiring
I have an '03 with the Land Rover trailer wiring.
the terminals are corroded so I'm going to rebuild/modify the housing to hold an American style flat plug. Does anyone know which wire goes to which function? I couldn't find it on the RAVE CD. |
RE: Trailer wiring
Pin 1 - Yellow LTurn/Brake
Pin 2 - Blue - Empty Pin 3 - White Ground Pin 4 - Green RTurn/Brake Pin 5 - Empty Pin 6 - Orange Reverse Pin 7 - Brown Taillights This link helped me out alot also... http://www.marksrv.com/wiring.htm |
RE: Trailer wiring
Or, clean your contacts and buy a convertor plug that will plug into your round plug and allow you to use the flat 4 pin plug.
Mike |
RE: Trailer wiring
Mike |
RE: Trailer wiring
Thanks!
The terminals are terribly corroded on the back of then unit - when I took it apart it was full of water, apparently the gasket was holding water in. |
RE: Trailer wiring
RE: Trailer wiring
Mine is just a small plastic plug that has the round connector on one end and the flat on the other end, most trailor shops have them.
Mike |
RE: Trailer wiring
The damaged piece is the part that mounts to the truck - where you would plug the above mentioned adapter in to. The damage from it being full of water is bad enough that one of the pins no longer has power.
I could replace the terminals, but since I only use the 4 flat plugs I figured I'd just install one of them. |
RE: Trailer wiring
That thing on Ebay looks homemade.
X |
| All times are GMT -5. The time now is 04:44 AM. |
