-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Trailer Wiring Harness (https://landroverforums.com/forum/discovery-ii-18/trailer-wiring-harness-559/)
MiniManiac Apr 10, 2005 11:28 AM
I am trying to hook-up a trailer to my 2003 discovery II. I looked under the bumper and I noticed a plug for a trailer wiring harness. The problem is this plug is flat and has six very small connectors. I have no idea what type of connector this is. The dealer harness is very expensive is the entire thing. All I need is some type of adapter. Does anyone know what I am talking about? I will post up a pic for you to look at. Thanks.
Bait Apr 11, 2005 12:00 AM
RE: Trailer Wiring Harness
Not sure what you are looking at. The trailer harness plug is located behind the R/R upper tail lamp assembly. Remove it and you will see A plug with A blanking plug in it. Yeah the Factory kit is crazy $. No need for that.
All you need is A standard converter to switch between the European system and USA. Available at most auto/trailer stores. Be sure to use the type of crimp connectors that are shrinking type. IE; you heat them up after crimping and the shrink around the connection to make A water proof connection.
MiniManiac Apr 11, 2005 01:05 PM
Thanks. I am just confused on what this other plug is for. I have a shop here in town that can hook up a harness kit for me. Thanks again.
MiniManiac Apr 13, 2005 04:34 PM
I solved the mystery of the 6 pin plug. It is the Rear Parking Distance Control plug. Of course, I do not have that in my vehicle so the plug is just hanging there. Anyway, I ordered a wiring harness from Atlantic British.
mikemeyer0 Apr 13, 2005 05:26 PM
i just bought a plug i needed and taped it into the wires behind the pass. brake light, you will have to use a tail light converter for the fact that it has seprate turn signals from the brake lights, there like 8 bucks or something. Very easy wire job to do. Use a test light or there is a wiring code on discoweb.org, good luck! oh yea, total cost to wire for trailer including trailer brake's, aux. power at trailer plug was just under $20.
MiniManiac Apr 13, 2005 07:29 PM
ORIGINAL: mikemeyer0
I went the easier yet more expensive route. Atlantic British has a harness that you simply plug in behing the pass tail light and TADA - you have a working harness!!
mikemeyer0 Apr 13, 2005 07:32 PM
yea, i looked at it and it is a tail light converter with a plug that meets the factory wiring. I found a place that sells that plug for $3, (after i cut mine off the car) and the converter is like $8. $11 to make what AB sells, some things are cheap there but some things they rape you. oh well. At least you got it done.
MiniManiac Apr 13, 2005 07:37 PM
I figured it could be done for less, but since this is new territory for me I decided to go with this source. A local hitch shop was going to charge me $135 to hard wire it in themselves. Compared to that price and the OEM price, AB isn't too bad. If I had more experience with this vehicle I am sure that I could have done the way you described. Anyway, thanks.
mikemeyer0 Apr 13, 2005 07:52 PM
kool, $135, maybe i should go into the business.
MiniManiac Apr 13, 2005 09:57 PM
No doubt. Everyone is a criminal!!
