-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Trans Fill/CheckPlug free flowing (https://landroverforums.com/forum/discovery-ii-18/trans-fill-checkplug-free-flowing-33742/)
Jupe209 Aug 29, 2010 09:20 AM
While checking the transmission fluid level I removed the fill/check plug and fluid came gushing out. I did have a clean catch pan under it and caught all of the fluid. Looks like about 4 quarts came out. I thought that it should only trickle out if it was at a proper level. How do I get the fluid back in and keep it from spilling back out? Is there undue pressure from somewhere causing this? Any thoughts?
Disco Mike Aug 29, 2010 10:56 AM
Well, now you get to do a fluid change. When checking the fluid level, you start the engine, shift drive to reverse 2 time, go back to park and with the engine RUNNING, you either check or add fluid to the tranny.
Jupe209 Aug 29, 2010 11:29 AM
Aha, should have checked it while engine was running. Headed to auto parts store now.
