transfer case/transmission/prop shaft issue
Wife's Disco. Front driveshaft failure. Knocked hole in tranny. Good Times! Removed shaft. Transfer case and tranny in neatral to get it home. Pulled trans. pan to inspect. No visable damage other than cracked case. Dropped valve body and disconnected wires. Put pan back and towed to a welder that specializes in aluminum. Did an amazing job. Got it home, re-installed valve body, pan, fluid, new prop shaft. Put 4 quarts DexIII back in. No leaks! Now put transfer case in H and tranny in N. Then park, rev., drive. Car acts like it wants to go forward in all gears except park. Slips. No reverse. No service lights. I'm thinking front differential or trasfer case or transmission itself. Did I miss something or did more damage occur than I thought?
Second of all, pics please.
Third of all, the next time I see any poster asking "if they should" replace the front u-joints and centering ball...I'm referring them to this post.
Good luck man and keep us posted.
Kenso
10-28-2014 09:05 PM
powderhound
07-07-2014 10:51 AM
