Transmission Cooler Lines - where to buy?
Old 08-13-2022, 11:53 AM
Mntnceguy's Avatar
Originally Posted by Harvlr
If you do use stainless, make sure you use some anti-seize on the threads. I doubt that the issue was over torquing. I’m an aircraft mechanic and we frequently use stainless AN (or more commonly MS) fittings. Unlubed stainless will gall up and seize.
I agree with that, Stainless will typically gall and seize, especially when in contact with Aluminum. That's why I was wondering if anybody had a connection for the brass ones, or even a price so I might know what to expect. Seems like a great idea, if you can find the product somewhere...ahh, the joy of supply chain issues, lol
  #22
Old 08-14-2022, 12:21 AM
Discorama's Avatar
14mm compression fittings fit on the radiator (some sanding required, because the tubing is about 14.2mm OD). Check out McMaster-Carr. All other parts (hoses, adapters) you get from summitracing. Should be possible to build the lines for under $200.
Jeff Blake
01-28-2017 10:32 PM
archaeology_student
08-22-2016 11:17 AM
Rover Nick
05-01-2014 08:40 PM
DarylJ
04-14-2011 09:11 PM
Quick Reply: Transmission Cooler Lines - where to buy?
